Generator wiring
I would like to connect my Genmax generator to my Multi Plus 24v 3000 Inverter Charger using the AC in terminals and configure it to auto start when the battery gets low during winter. I want to use the charger in the Multi Plus. Is this possible? The generator has an auto start feature but I need the charger in the multi to charge the 24v batteries when solar is low. What are the connections. I don’t see it in the manual anymore.
This is certainly possible using a relay assistant … There are several things to clarify … what type of generator is it, and how does its auto-start function work … e.g. a continuous signal, or does it need a defined start/stop signal via an adapter … then the Multi first has to accept the generator on AC-in.
And you can already find all the information about connecting a generator here in the forum … Use the search function first, and then we’ll be happy to help with any further questions …
I tried the search function but didn’t have any luck. A 2 wire connection cable came with the generator with a green connector on one end for the multi and a plug on the other end for the generator. I’ll purchase some number 6awg cable and a plug for the 50 amp connection then wire it to AC-in. I think after that it’s just change the settings and the switch on the Multi?
do you happen to have a model number or a link to the manufacturer for us … it initially sounds like JUST a simple emergency start via a normally open contact … closed = engine starts and runs … open = engine switches off … pure speculation :sweat_smile: but that would be the simplest solution for integrating a relay assistant.
I do exactly that using a programmable relay assistant with the built-in K1 relay. I only had to program the assistant to close or open K1 as desired. Of course, you can use other supported relays. I believe the multi has a dedicated generator assistant but I don’t use that.
GENMAX 6250wiet Tri-Fuel Silent Inverter Generator(2026Model)Features 2-Wire Auto Start/Stop,bluetooth APP Control,CO Sensor,Digital Display&50A Outlet-Ideal for Home Backup&Camping Outdoor,EPA Compliant
I have the same Genmax. If you have a Cerbo you can connect the included two-wire leads to one of the Cerbo relays (usually relay 1 but I think you can use either 1 or 2). For my set up I have black on NO and red on COM as in the photo below. You should see your generator as GENSET in the Cerbo Device menu. Clicking on that will take you to the manual and autostart menus.
I do have a cerbo and I think that this way would work well but I thought it might be better to use the connections on the multi. I will be using the ACin connection on the Multi and maybe the dedicated relay. I guess I’m just not sure what the best way is to do it. What size wire did you use for the charging and where did you connect at both ends. I plan to connect to the Multi to the Genmax 120v large plug with aw6 wire but I think that I can only get 30 amps out of the generator.
