hi, we have two separate systems where the generator autostart isnt working, including with genset. we dont have battery monitor or shunt. we have gone through all the manuals and datasheets to ensure that it has been installed/connected correctly with the right settings and they all seem to be correct. however, both systems seem to still not be responding to the generator autostart.
does anyone have any advice on what we have done wrong or how we can fix this? thank you.
both systems are 2v traction cells 800 ah. one system with multiplus ii, the other with quattro, both mppts, off grid
both generators start by shorting the control wires
problems seem very random, if you use manual start on touchscreen it works, but doesnt start and doesnt stop randomly. they are in completely different areas with different clients. both are remote so its difficult to be there and see/hear if the relay switches on.
Are you using the relay in the Multiplus/Quattro or the relay on the GX device to send the start signal. Is this a recent problem or recently realised due to a change in the weather? Are the systems newly installed or installed for sometime. Are they on the VRM? What is the FW version on the GX device. Can the client hear the relay click?
