Hello, I wanted to monitor de grid frequency using nodered, but the frequency is stuck at 50.103 and never change.
We can see the same behavior in vrm 50.1.
So my question is: do the Multiplus really monitor the frequency or it’s just a fancy number ?
Thanks for your help
@Gabius
Are you expecting it to change?
It will if you have AC couple PV and are not connected to grid; maybe a generator that runs above or below 50 so the system synchronises to that. Otherwise it should remain at 50.
If you look closely there is two values ( one under 50 one higher) so it’s strange to have the same digit
At least it’s what I see in my freq output, for the In frequency it stays at 50.10256576538086
I would expect that as I am not grid attached currently so frequency won’t be synced to the dodgy grid. I would expect a fairly stable frequency while in inverter only.
Can you provide the firmware version of your multi ? cause i see this this behaviour for a year or two, with 4 different multi II ( on the same location btw)
Do i need to activate something ?
The datapoints here may be further apart on the website one? Vrm logs minute to minute on mine.
The data shows changes when the grid does change. (I have it set to only changes in the messages.)
node red frequency debug message
The reading right by their data source can be different to yours anyway given that there are transformers and other infrastructure inbetween as well as loads and devices that affect the frequency.in your locale.
A further thought. The grid operators will have dedicated measuring and monitoring equipment. The Victron is not a calibrated measuring instrument. So its good for a general idea of what the grid is up to and synchronises to that to do its job.
