Question about SmartShunt
Hello everyone,
I have two solar panels on board, each charging a LiFePO4 battery via an MPPT controller, through a shared shunt and a 712 Smart Battery Monitor. It works perfectly. Now I’d like to connect a wind generator. It’s only a small Savonius rotor, but I’d like to know how much power it produces. I’d like to connect it via a SmartShunt. But how do I do that? In parallel with the existing shunt? But then the 712 Smart Battery Monitor wouldn’t measure its output, would it? Where am I going wrong?
So many questions…
Many thanks in advance
Hello Klaus :waving_hand:
You simply need to connect the shunt in series with the wind generator in the negative lead. The shunt will then measure the hopefully measurable current and the power generated as a result. The old 712 shunt will continue to measure the energy generated by the overall system … as with the MPPTs …
Hello Steffen,
Thank you for the quick reply.
I’ll implement it that way.
Best regards,
Klaus
Good luck :grinning_face: … and remember that this new shunt also provides an auxiliary connection for taking a temperature measurement!
Thank you. But I’ve already connected a Smart Sense. (I hope I’m not mistaken) :thinking:
:+1: … it’ll all work out … if need be, just “dial in” here again :smiley:
