Sunny day forecasted with battery charge, EV charge and a little consumption. Result is therefore a fully booked 17kW grid connection. Leaving all other numbers aside that shift accordingly this is what happens.
Result in forecast:
Solar to battery = 0, Solar to consumption = 1.5kW
Actual result 15mins later:
Solar to battery = 1.5kW, Solar to consumption = 0
No matter the numbers and actuals. The forecast says „going to use all PV for consumption“. The result is „going to store all PV to battery“. The PV forecast and consumption forecast themselves are not that far of. It’s just a matter of where to map it against:
The yellow forecast becomes green and the purple forecast becomes red. Solar to Consumption becomes Solar to Battery and Grid to Battery becomes Grid to Consumption. Totals are still about the same.
