Our DST ended this weekend and I noticed 2 issues with my VRM forecast chart below:
The hover-over for any adjusted forecast values show times ending in XX:45 - YY:44. I believe it should be XX:00 - XX:59.
Our EV is scheduled to charge at 9pm, and has been for many months now. Last week, VRM would correctly forecast it at 9pm. However the forecast is now showing the EV charge at 8PM. This is suggesting the consumption forecast is now ‘off by one hour’ due to the end of DST.
Could someone please look into these two items?
Solar forecast looks correct (shifted up by one hour). It’s just the consumption forecast shouldn’t have been shifted by an hour.
I’d first check the time and time settings on your Cerbo and see whether it’s already correctly set to winter time or not.
Check the time on your Cerbo home screen and the time and time zone settings in Settings. Note that the time in Settings is in UTC, not local time.
I reported that last September, and it was fixed straight away. I haven’t checked yet whether the bug has come back. I no longer use a fixed time, but now I automatically switch the boiler on when the price is lowest. So that changes every day and is less noticeable than a fixed time.
So when adjusting the forecast, if I adjust 8pm it correctly applies that to 8pm on the chart. But a bit weird that I’m seeing the unadjusted EV charge forecast show a spike at 8pm when it should be 9pm.
