I’m new to the site and would like to find out more about how the MultiPlus II - 4K works.
I’m about to receive a MultiPlus II - 4K.
Can the MultiPlus be programmed so that it receives 60 Hz at the input, charges the batteries, and distributes 50 Hz at the output via the inverter?
What configuration should be programmed in this case, if this is possible?
Thank you for sharing your knowledge.
Eric
