[Feature Request] - Feed-in logic
I have ESS system using of 3x MP2 inverters across 3-phases. When there is a surplus energy and my battery is full the energy flows out into the grid. This works well. The issue is a logic how the energy is distributed out across 3 phases. Since this system is capable to do asymmetric power feed-in my suggestion would be to distribute the energy based on phase-voltage. The lower voltage is, more energy will flew through out the phase. This logic will improve the stability of power grid which will have possitive impact on overall power grid network.
Can someone from Victron comment this? Thank you.
