The short answer is no and not likely to be.
The meter is too slow for ESS applications especially when used to prevent feedback.
I know your set up is not an ESS application but when enabled for one, it is enabled for all. (Then queue the tonnes of silliness for support and the posts complaining.)
Then the inverter actually measures its own input, so I’m guessing you do have loads before the inverter.
As an FYI your post has triggered the AI filter several times. Please edit it. It is against community guidelines
What do you use to charge the batteries, then? I’d have thought something like a MultiPlus, which can measure shore power just fine too, can’t it? Or do you use something else?
