I have a 3-phase ESS/DESS system with 3 x MultiPlus-II 48/5000, MPPT 450/200, Cerbo GX and VM-3P75CT ( and 135 kWh in batt. ).
I am wondering if DESS can make better use of the available current on each individual phase when charging the battery from the grid.
As a simple example, my grid connection is 3 x 20A. Assume the house is currently using:
L1: 8A
L2: 5A
L3: 18A
This leaves 12A available on L1, 15A on L2, but only 2A on L3.
If DESS wants to charge the battery with around 6kW, is there any way for the three MultiPlus units to use more charging power on L1 and L2 and less on L3 ?
In other words, I would like the system to dynamically use the available headroom on each phase, while never exceeding 20A on any individual phase.
There is enough total capacity in the example above ( 12 + 15 + 2 = 29A ), but it is very unevenly distributed between the phases.
I know about the ESS “Total of all phases” and “Individual phase” settings, but I am not sure if either of them can actually do what I describe above when DESS is charging from the grid.
I also found the earlier discussion about the 3-phase grid current limit issue. As I understand it, that is not quite the same question. I am specifically interested in using the different available current on each phase for battery charging.
Is this already possible with ESS/DESS?
If not, I think it would be a useful feature, similar to dynamic load balancing on a 3-phase EV charger.
/BR
Erling Anderberg
