Feature Request: Customizable VRM Energy Flow Diagram for Third-Party Inverters
Hello Victron Team,
I would like to suggest an improvement to the VRM energy flow diagram, especially for installations using third-party inverters.
My off-grid solar system includes:
  • A third-party inverter (not a Victron inverter)
  • Victron Cerbo GX
  • Victron VM-3P75CT energy meter
  • Victron SmartSolar MPPT charge controller
  • Victron SmartShunt
  • SDM630 energy meter integrated through Node-RED
The current VRM diagram has three issues:
  1. Grid: My installation is off-grid, but the energy meter is displayed as “Grid”. It would be useful to select a more appropriate label, such as “AC Output” or “AC Loads”, for systems using third-party inverters.
  2. AC Loads: An empty AC Loads block is displayed even though no corresponding data is available.
  3. EVCS: I previously selected the EV charging station role by mistake on my VM-3P75CT energy meter. After correcting the configuration, the EVCS device disappeared from the device list, but the empty EVCS block remains in the VRM diagram.
Suggested improvements:
  • Allow users to hide unused blocks such as AC Loads and EVCS.
  • Automatically remove obsolete blocks when their devices or roles are no longer configured.
  • Allow users to select appropriate labels for AC energy meters.
  • Improve the energy flow diagram for installations using third-party inverters.
  • Display relevant inverter-specific elements automatically when a compatible Victron inverter is connected.
I have attached photos of my actual installation and the current VRM diagram to illustrate the issue.
I hope these improvements can be considered for a future VRM update.
Thank you for your work and for considering this suggestion!
Can already be done… Set it on the meter itself.
The EVCS usually only exists if you have one. That is not normal and possible related to config error on your system.
Thank you for your reply and suggestion!
I have already tried changing the Victron VM-3P75CT energy meter role from “Grid meter” to “AC load”.
Unfortunately, after changing the role, the AC power readings are no longer displayed in the VRM energy flow diagram as they were before.
My system is off-grid and uses a third-party inverter, so I would like to display the actual AC consumption correctly.
Also, the EVCS block remains visible even though I do not have an EV charging station installed.
Is there a way to remove the unused EVCS block and display the energy meter readings correctly as AC Loads without losing the power data?
I have attached a screenshot showing the current situation.
Check in vrm device list and see if there is ‘device’ that needs to be deleted. But any data attached to that device will be deleted no avoiding that unless you downloaded the data first for personal use.
After setting the AC load role, then technically it may be possible to set its position on the gX. I’m not sure there. I haven’t used it there yet.
Thank you for your help!
I have already checked the VRM device list, but there is no EVCS device listed, even though the EVCS block is still visible in the energy flow diagram.
The EVCS block originally appeared after I accidentally selected the EV charger role in the energy meter settings. I later changed the role back, but the EVCS block remained.
I would prefer not to delete any devices or lose historical data.
Is there a way to clear this old EVCS configuration from the VRM diagram without deleting devices or historical data?
The ACLoad Role itself will not be displayed as consumption.
Consumption comes from the gx calculation, calculated by using the Victron-Inverters reported ACIN and ACOUT values along with all other figures.
Without these values, there will be “0” and acloads metered will always be included in that consumption, not additional, this role is designed to split a “5000 metered consumption” into it’s interesting key-consumers, not to measure something additional out of the victron inverters visibility.
Third party inverters (except pvinverters) are not supported, neither in Venus nor in VRM.
