Fastening data cables - Cerbo GX
Hello, could you recommend me some sealant or glue for fixing cables, e.g. in direct inserted into Cerbo GX on a boat?
Thank you
I don’t use glue. I try to find a fixed point nearby to tyrap the cable around. So in case of faultfinding, its easy to disconnect.
I have found this as well. If the cables are secured and there is no weight on the connections they stay alright.
I have seen some people use hot melt glueas well as an extra precaution as you can pull it off when you need to.
