Fast control loop for EM24 on MultiPlus-II GX
Hello everyone,
I’ve got a MultiPlus-II GX 48/3000, Pylontech US2000B + US2000C and an EM24 set up as an ESS.
My Multi is running on Venus OS v3.00~32 (yep, that old Beta) without any issues. I’ve had no problems at all since I installed it. I really like the fast control loop, it makes a difference.
I recently helped with the setup of the exact same configuration as above. Is it possible to get the appropriate image of Venus OS v3.00~32 for the MultiPlus-II GX 48/3000?
Or is there any possibility to implement the fast control loop for the EM24 (maybe as a switch with a warning or so) in the next release?
Kind regards
AthlonFX
Image repository is here.
As far as I can see, there are no Beta images available.
Betas are not there. You are a long way behind and won’t find help on an outdated beta. Please update. You are unsupported in the way you are running.
