EVCS Modbus TCP without GX device
Hi!
I’m trying to communicate with a EVCS charger via modbus TCP without a GX device but unfortunately It doesn’t work.
I’mtryng with Home Assistant and via PC software that emulate a modbus client but nothing.
I’m using the IP address of the station, port 502 (default of the protocol)
Anyone have some advice?
Thank you so much!
Leandro
Did you get it working eventually?
I also use my Victron EVCS without the GX device. This works fine. This is my home assitance yaml:
  • name: EVCS
    type: tcp
    host: 192.168.2.17
    port: 502
    delay: 2
    timeout: 5
    sensors:
    • name: “EVCS_ChargingActive”
      address: 5010
      scan_interval: 5
    • name: “EVCS_ActChargeCurrent”
      address: 5018
      scan_interval: 5
      scale: 0.1
    • name: “EVCS_ChargerStatus”
      address: 5015
      scan_interval: 5
      switches:
    • name: “EVCS_StartStop”
      address: 5010
      command_on: 1
      command_off: 0
      scan_interval: 10
      verify:
      input_type: holding
      address: 5010
      state_on: 1
      state_off: 0
    • name: “EVCS_AutoCharge”
      address: 5049
      scan_interval: 10
      command_on: 1
      command_off: 0
      verify:
      input_type: holding
      address: 5049
      state_on: 1
      state_off: 0
