EVCS is once again not connected to CCGX
Hello, Unfortunately, there is once again a connection problem between my EVCS and the CCGX. Both devices have an internet connection, but the EVCS is shown as “not connected” on the CCGX. I also can’t check the battery state of charge on the EVCS, and there are no settings available for the EVCS via VRM — although Smart Solar is fully visible there with all its data, it offers no control options.
Interestingly, yesterday, despite the connection to the CCGX already being interrupted, I was able to update the firmware directly on the EVCS from version 2.08 to 2.09. Since then, I have restarted the EVCS several times, but the connection to the CCGX has still not been restored.
I would appreciate your help resolving this issue.
Kind regards, Sigi
Since you have updated the firmware on the EVCS, it might be worth checking that your GX is still defined correctly in the EVCS settings
Hi David, thanks for your suggestion. But the connection was already gone before the update. The entries are present and OK.
The VRM portal ID is also displayed correctly.
Has the IP address of the GX device perhaps changed?
I’m not sure whether this works with the old CCGX, but with the latest firmware on the EVCS, you can also switch communications to MQTT.
It may be that a newer firmware version is required on the CCGX for that, though.
Hello Matthias,
No, that hasn’t changed. Also, as I already mentioned, the firmware was updated to the latest version yesterday. This is now the third day the issue has been occurring, even though nothing has changed on my end. I did have similar issues recently, though, which were then fixed by the Venus team.
As you can see, it switches from connection error: yes to no and back again. But the device doesn’t restart when it loses contact.
Check the DNS server settings in the CCGX.
In my opinion, this points more towards a network issue, or a problem with the CCGX.
Can the EVCS be reached on the network via its own IP?
In EVCS, the network connection check displays exactly the right information. Everything is also shown as connected on the provider’s website.
Restarting the entire system brought everything back online overnight, and it’s working again.
That’s great news.
Which piece of equipment in your system do you think changed/fixed itself during the reboot?
I think the EVCS has connected to the GX again.
