No, same chip
Yes
There is nothing producing heat inside the unit, not sure what heat dispation are we talking about
V1 is already certified for that
What is the curent version not doing properly offgrid?
Ok my Charger lost connection again while it was auto charging today, I logged in with BT and got an error comunication message. screenshots attached. I also attached screenshot from the wifi controller. The wifi didn’t drop but the ip was not accesible. While I stood in front of the charger it just restored the connection and started charging, it was offline for about 5 minutes. In that time I couldn’t ping it from the network or acces the webpage and the instance dissappeared from the gerbo’s screen. You will see that the connection was up for 20 plus hours and after the charger started working again withour a power cycle it shows the wifi connection wasn’t severed. this is the first time I see this before I had to powercycle it.
Yes, I read the whole thread from beginning to end. I now have a dedicated wifi accespoint for the charger at 20mhz channel width, -47dbm signal. I had an openevse charger connected to the same accespoint for 3 years no issues. Out of my previous post you will see that the charger never lost wifi connection it just stopped comunicating on the ip.
Ultimately, the responsibility falls on me. For clients with high-end IT infrastructure that causes the EVCS to crash, I install a Wi-Fi bridge inside the unit, specifically, a PoE-powered MikroTik mAP lite. With this setup, I use to observe repeated shutdown cycles only when the station is exposed to hot air and direct sunlight.
Noted, nevertheless, regarding the new European cybersecurity regulations, a global security concept whitepaper form Victron Energy or a datasheet form you will be appreciated.
In off-grid with mode “Auto Mode”: With a LFP battery at 100% of SOC, I often sound it impossible to start the EVCS. I also experciced exessive battery discharge at sunset. => the best solution for me would be to transmit real time PV potential to the EVCS via Node-RED using data from either a generic pyranometer or directly from the excellent SolarSense 750.
I presume the mikrotik is restaring, not the EVCS. The EVCS was testes in extreme conditions and it should not be restarting.
Yes, the cybersecurity ceritfication will be shared. But I can confirm already that we have it.
We are working on a different Auto mode, controlled by the GX, that will use the data from the solar sense, the power prediction, the energy prices etc
Just to report on this. It became unreachable again, I reboot the ap and the chargers wifi reconnected again but the comunication didn’t get restored. It can’t be reached via ip. I did login in via bluetooth, shows wifi connected shows ip but can’t comunicate. A reboot is only thing that fixes it.
