have EVCS with firmware v2.09/5.2 connected to Cerbo GX, 3*Multiplus II 48/3000, 60kWh PV battery, 20kWp PV modules, BYD Dolphin Surf.
EVCS configuration:
mode = manual, current = 6A. location = acOut
start charging at backup battery SoC: 90%
stop charging at backup battery SoC if off grid: 85%
Allow battery/grid power for auto mode: enabled
Allow low excess solar power for auto mode: enabled
it is midnight (no PW power), PV battery is at 83%. I click “start charging” and EVCS starts to draw 4.1kW from PV battery although SoC is below min SoC. PV SoC drops from 83% to 79%.
I don’t wan’t to charge from (pv) battery to (bev) battery overnight. how do I set up:
“if there’s no PV power and PV battery is below min SoC, use grid power to charge vehicle”?
as of now, I manually set the grid setpoint to 4000W. but if I’m asleep when BEV battery is full, the PV battery will be charged from grid - and that is to be avoided.
ps: reading similar topics, connecting the EVCS to AcIn is recommended. but this is not an option here.
If you have the ESS assistant running you can set a scheduled charge event.
During this event, ALL your ACout loads will be fed from the grid.
The house battery will be charged from the grid only up to the chosen SoC %age. You can set this very low if you don’t want any house battery charging to happen.
The configured SOC is only for the automatic mode in manual it will always start to charge.
I guess with NodeRed you could automatically set the grid setpoint the the EVCS charging power that way the setpoint would go down after the EV is full.
Matthias - When I set the grid setpoint to (i.e.) 8kW and after a while the BEV is fully charged, the PV battery would be charged with 8kW until it is full, right?
Yes, that’s it. You set start time, duration and target house battery SoC.
During the scheduled charge event, If the house battery is above target SoC, it will not be charged. But other loads on ACout will be fed from ACin and NOT from the house battery.
