We were very pleased to see the EV Charging station V2 listed in the VICTRON price list “Pricelist_Victron_EUR_C_2026-Q4_Web.pdf”. If I understand correctly, it would be compatible with V2H/G.
Apart from its price, does anyone know a bit more about its specs?
Hi, yes, it will be V2G compatible, but with an aditional communication module. It is an expensive module and it is not a good idea to be added inside all the units.
What car brand/model do you have?
I’m following this topic with great interest. @Lpopescu I’m torn between the Hyundai ioniq5 (an older model, but still cutting-edge when it comes to 800V DC) and the VW ID.Tiguan (a refresh of the ID.4). Are these two models OK too? And what sort of timing are we looking at?
Our V2 EVCS is an AC charging station. With that extra module, it will be capable to offer bidirectional charging for cars that support bidirectional AC charging.
Bidirectional DC is a completlty different storry.
In a VW ID.5, my onboard computer indicates “bidirectional charging” — V2G? / V2H? — with a limit of 4,000 hours/10,000 kWh. I don’t know whether this is the same for other vehicles.
Many vehicles will require a software update to be compatible with bidirectional AC charging. @Dvi: the Ioniq 5 is one of them @Bob: as far as I know, the VW ID.5 only supports bidirectional charging over DC
Thanks @Lpopescu for your reply.
So if I understand correctly, we’ll have to buy the V2 terminal for €813 + a “COM module”.
Then you say it’s not “wise to integrate it into all the units” — that’s where you’ve lost me; there must be a translation issue
Since the price is known, why can’t we access the specs?
Details will be available as soon as the product is in stock.
Enduser pricelis is published every quarter. Since the product will be available in this quarter, it alos contains the prices.
Will the Victron bypass whatever the car sends it, or does it have some kind of synchronisation with the mains supply coming from the car? In other words, does the synchronisation with the grid have to come from the car’s own inverter, or can the Victron charger adapt a V2L signal so that it synchronises with the mains supply in our homes? Or does the car need to specifically support V2H or V2G to synchronise using its own inverter?
Your car has to be V2H/G compliant, because the onboard charger does indeed play a key role in how it works.
A car like @Dvi’s Ioniq 5, which supports V2L, will only be able to do V2H/G after a software update, because its onboard charger supports bidirectional charging, but that’s not the case with all V2L-compliant cars.
Of course, the charger has to be bidirectional hence this V2.
Will the old version of the EVCS continue to be sold alongside the new version once it becomes available, or will the old version be withdrawn from sale immediately?
There are two points that need to be clearly distinguished:
Is this about AC-BiDi or DC-BiDi?
Is the application V2H or V2G?
Re 1.) With AC-BiDi, the OnBoardCharger (OBC) is responsible for the conversion (AC<->DC), and an AC wallbox of “whatever kind” doesn’t have to do “anything”. In principle, it only has to convert the signal from the (H)EMS into a PWM signal for the EV. In Germany, however, things get more complicated, as the FNN/VDE requires the AC wallbox and OBC to be certified “as a unit”. This is logical in itself, but complex, as the AC wallbox has to handle, for example, grid disconnection (2 contactors). There are also the requirements for the OBC, including Q(U) & P(U) control.
Whether an EV manufacturer would want to take this on remains to be seen; i.e. Renault has not approved the R5 for AC-BiDi in Germany.
Re 2.) Just as with AC-BiDi, the EV also has to explicitly support DC-BiDi. With DC-BiDi, the critical point is the DC contactor between the traction battery and the CCS socket. On open-WB, you can find a regularly updated list showing how the different eKFZ behave when discharging. The behaviour ranges from “panically” opening the DC contactor to “doing nothing” (the best case). The big advantage of DC-BiDi is that everything happens outside the EV. The grid codes have to be met by the DC-BiDi wallbox; the EV is 100% out of the picture.
Anyone who has received a clear statement from their supplier about the technology for their EV would be well advised to get written confirmation that the desired wallbox can be used. It’s no coincidence that there is only one DC-BiDi wallbox for the BMW iX3.
A side note: VW and its MEB platform are de facto a no-go:
Minimum discharge of 1.8 kW
DC-BiDi wallbox prices beyond “all reason”
Once you have overcome the technical hurdle, you can then look into the V2H or V2G applications.
