I can’t find anything in the docs about using different IP address ranges for the EVCS. I’ve got a LAN cable in the garage, but it seems there aren’t any mesh-capable repeaters for Vodafone Station routers, so I’d like to know whether the charging station can still connect to the Cerbo via MQTT. Or is there any workaround to get the two to see each other with the setup I have? For example: Vodafone Station 192.168.0.xxx
Some Chinese repeaters are in router mode by default*. You can change this on most of them, though. I can’t tell you exactly what the setting is called.
Often set up their own Wi-Fi network
Create a new network segment and act as the gateway and DHCP server for that network
