ESS is not working,
ESS Dynamic_ESS OFF, What am I doing wrong?
Cerbo v3.713 fase system, 3x multiplus II 5k6 firmware version 2602 599, 1x Cerbo GX MK2 v3.71, 1x VM-3P75CT VE.Bus connected v1.11, 2x 32kWh Seplos battery with BMS
The week before last, the washing machine worked well with the self-generation setting; however, after a few days there was a problem, so I cleared everything. Last Thursday or Friday, I tried to set up the ESS, but I ended up in a loop. That was resolved last weekend; however, I can now access the dashboard screen (normally a green icon appears in the top right corner allowing you to set the ESS to “hold battery full” or “optimized with or without Battery Life”). This icon now appears very occasionally with the message “connecting” but then disappears again quickly.
real time is also missing
afbeelding”Normal”
“my installation”
I would like to hear what the solution might be. G.
Please provide a detailed problem statement and overview of your system, wiring, configuration etc.
There is little in that short statement that will allow anyone to help.
If English isn’t your primary language, we also have some other categories that are language specific.
I don’t know what happened, but 5 minutes ago the real-time and the icon suddenly popped up on the screen, SOLVED
Thanks to everyone
