Error Code #159 in Color Control
Good morning everyone, how are you?
I have a problem with monitoring in my installation. In VRM monitoring, my plant shows that it is in “real time”, but it is not showing the information correctly. In order to understand what was happening, I accessed the “VRM online portal” configuration through the color control and it shows error #159 and the message (Error message: [(‘PEM routines’,‘PEM_read_bio_ex’, ‘badbase64 decode’), ('x509 certificate).
I would like to know what this error means and how I can solve it!
Is your GX software version up to date?
Yes, update.
Error 159 is an interesting one to diagnose. You need to be able to understand the error message to follow.
You can maybe disable https as well, for some networks i have found this necessary (- like mobile- use of vpns)
