Bonjour, j’ai mis en service une installation avec ESS, suite au branchement de la terre, j’ai l’erreur #11
MultiPlus-II 48/5000, Erreur #11 apparue dès la mise à la terre du châssis. AC-In ok (1,3V entre N et T). En sortie AC-Out (terre débranchée), j’ai 96V entre N et T et 135V entre P et T."
Your topic was created in the wrong section and does not show any signs of expert-level discussion. Your section is DIY, and there you may request assistance from the community regarding why the earth relay is failing the test. First and foremost, I recommend that you carefully read the relevant section of the Victron knowledge base on grounding and the operating principles of the equipment. After that, carry out all necessary checks to verify that your actions are correct.
