Energymeter with S0 bus
Is it possible to use a energymeter with a S0 bus output? I have one that gives 2000 impulses per kWh. This is basicly a dry contact that opens and closes every 0.5 Wh of energy.
I can use on the cerbo Digital I/O an impulsmeter, in the setup I can select cubic m, liter, gallon as a voulme unit. It would be nice to have Wh as a unit also.
Any suggestions ?
Wim
You can covert in Node Red with this Node
node-red-contrib-watt2kwh
