I am currently working on a hybrid setup. The batteries will be Victron NG coupled with Lynx BMS NG. The Orion XS is going to handle DC-DC charging. The inverter/charger however is going to be a non-Victron one. Due to existing local monitoring systems and shape/space contstrains we are unable to use Multi Plus or Quattro. The inverter/charger could be easily controlled via the Allowed to Charge / Discharge signals. The charge profile on the other hand is adjustable to work best with the Vitron NG batteries. So proper charging is not a concern.
However, I would like to be able to display the 230 VAC values of the inverter/charger on the Ekrano. I am planning to use Energy Meter VM-3P75CT. 3 of them- one for AC input, one for AC out 1 and one for AC out 2.
My question is;
Can I set the Energy Meter to display values like shore, ac loads etc (just like it does with a Victron inverter/charger)?
Thanks
DK
