Energy meter roles
Hello all,
I have a system with:
Multiplus 48/5000VA
3x MPPT 150/35
Venus GX for control this main system firmware v3.53
5x Pylontech US2000 + 1x US3000C
I also have a separate old system for garden pump, deep well pump and water heater use:
2x Multiplus 48/3000VA in parallel (chargers are disabled and there is no MPPTs connected)
Energy meter CG EM112
CCGX for control and access pump system 2x3000VA
These two systems share the same battery bank
Pump system is always switched off during the night and morning time.
EM112 Energy meter is connected AC out1 of my pump system (2x3000VA), BUT it is connected to my main system (venus GX, Not to CCGX), so I can see consumption of the pumps and water heater on my venus GX. Role of this energy meter is usually “generator”, so I can see also consumption in VRM. Sometimes I change the role from “generator to “EV-charger”, so I can see “separate EV-charger box” on new UI.
Its important to see the loads of these both systems at the same time, so I don’t overload my pump system!!
Is there any chance to rename EVCS and give a custom name, so I could see on control panel 2X3000VA, NOT EVCS or generator or is this kind feature coming any time soon with firmware v3.60
I know that on device list I can see it as 2x3000VA, but would be great to see it also on control panel and VRM
Both systems are 98% offgrid.
Thanks :blush:
