Perhaps not relevant, but just to be on the safe side:
I’ve been using a MultiPlus Compact (MPC) and Cerbo GX, JK BMS and Homewizard P1 meter for a year.
Everything is visible in VRM.
Because the MultiPlus was very old, it no longer supported assistants, so it didn’t support ESS or anything like that either. It was purely an inverter and battery charger.
Although I could see the P1 data under Grid in VRM, the MP didn’t use it, so I had to set the charging current manually during the day.
I ordered a Multi RS Solar (MRS), which was delivered today.
I replaced the MPC with the MRS.
Grid code: Europe, No feed-in, ESS without BatteryLife. AC input type: grid.
AC-PV connected to AC-in, no DV-PV.
I tested the MRS by having it only invert (off-grid): it works well.
After that, I connected the MRS to AC-in and tested it by having it charge the battery from the grid: it works as expected, and the AC current limit lets me control the charging current. So far, everything is OK.
Next, I connected the Cerbo GX to the MRS via CAN. In the VRM portal, I removed the old MPC and set the MRS as the new inverter/charger.
In the VRM portal, I can see the MRS, JK BMS and Homewizard P1 data, and the readings are correct.
So far, everything is as I expected.
Next, I enabled Energy meter support.
That doesn’t seem to work: I get the error message “Energy meter missing” on the MRS display (and in VictronConnect).
The “grid” power measurement in VictronConnect for the MRS is clearly the MRS’s internal measurement and doesn’t match the grid measurement I see in VRM, which shows the P1 data.
Does anyone have a suggestion for how to solve this problem?
