I want to use ESS on my houseboat, but the Color Control shows “ESS assistant not found”. So the ESS assistant is not installed in the Multi.
My system has been working well for years, so I’m a bit hesitant to change anything. Still, I’d like to set up ESS, because it’s better for my lithium batteries (not sitting at 100% all winter) and it reduces shore power use by making better use of solar.
My system:
Color Control GX, firmware v2.51
Multi [fill in model]
3x Pylontech US2000
MPPT solar charger (DC coupled)
Shore power only in winter, 10 A. Off-grid the rest of the year.
Goal in winter: Optimized with BatteryLife, minimum SoC 50%, no feed-in to shore power.
Questions:
- What is the safest way to load and set up the ESS assistant for a beginner?
- Does ESS work well combined with months off-grid in summer?
- What should I watch out for so the current setup keeps working as it does now?
Thanks in advance!
