EM 24 has frozen
Hello
The EM24 (latest firmware) somehow glitched, and the ESS switched to bypass. This is the first time it’s happened in four years.
The strange thing was that the hoped-for reset by disconnecting the N (350 mA fuse) at the device just left the meter running. So I had to switch off the three phase conductors, then use a torch to re-enable the meter for Tibber :upside_down_face: Apparently the GarloGavazzi also gets its supply voltage from 400 V across two Ls?!
The depths of the menu on the smart meter are unfathomable; there’s probably a soft reset in the control panel too?
The EM24 gets its supply voltage from L2 and N, or from L1 and L2, so disconnecting N won’t achieve anything.
I think there’s also an option in the menu to reset the settings, but I don’t know whether that would have helped in this situation.
