Has anyone connected the EM 111 to a Cerbo GX?
What do I need to configure on the EM 111 for the Cerbo to recognise it?
Which connections should I use?
Many thanks
Many thanks
I haven’t installed the EM111 myself yet, but since it’s on the list of supported meters, it should work without any problems.
You need the Data +, Data - and GND connections. Check the EM111 manual to find out which terminals these are.
On the Victron RS485 cable, orange is Data +, yellow is Data - and black is GND.
You can work this out, for example, from the manual for the older ET112.
Thanks
I’ll test it.
