Eltek Flatpack2 PSU 48V- power LED blinking
Hello everyone,
I have implemented an ESP32-based controller for the Eltek Flatpack2 with Home Assistant integration(GitHub - taHC81/Eltek-Flatpack2-ESPhome: Monitor and configure Eltek Flaptak2 PSU using ESPhome). The setup has been working well for voltage and current control. However, after connecting a 2kWh Li-Ion battery (~41V), the PSU functioned correctly for a few minutes before shutting down. The cooling fan stopped, and only the power LED (green) is flashing.
Currently, the unit is not providing any output voltage, and the CAN bus communication is sending only zeros. Could this indicate that the unit has entered a protection mode? If so, how can it be reset? Has anyone encountered a similar issue?
Any insights would be greatly appreciated.
Only this from the manual (not much help - sorry)
Power (green) ON Module is powered
Flashing System controller accessing information on the module
Manual
