Hello!
Can you assign a function to relay 2, or can it only be used as a switch?
I’d like to use this relay as well, like relay 1, for automated switching based on the SOC value.
I need two different values for different devices.
Any ideas?
Hello!
Any ideas?
Unfortunately, for something like that you’d have to control the second relay via NodeRed. If it only needs to switch based on SOC values, though, that’s relatively easy if you know the basics.
I’m not exactly a nerd, but I’ve managed to get quite a few things done with my off-grid solar setup so far.
So, I won’t have to write any actual code now, will I?
I’ve found something about Node-RED, so I’ll read up on it.
Let’s see if it works.
I wasn’t a fan of Node-RED at first either, but then I attended a free training session run by Victron.
Once you’ve understood the basics, creating simple flows shouldn’t be a problem.
