Easysolar II GX - get correct SOC with internal battery monitor
You knowing the actual temperature is different to the system knowing the temperature.
So the soc on your system comes from the inverter. The system being able to calculate separately is possible with a virtual battery using node red then post calculation is possible.
well, the system is measuring the temp… (I know it from VRM)
again, that might be the case, as is an install with a shunt or BMV.
What strikes me, is that I am trying to do something, that is the absolute standard application for an easy (if you don’t have solar, somebody would use a multi). And still I don’t manage to get it right. That does not seem typical Victron at all. Is it really just that? Not missing anything?!
Thanks for your input! If there will be no further ideas/solutions coming up in the near future, I might try to get one, but until then, I will keep trying…
