I have been looking to enabling DVCC on my motorhome system.
My setup is on screenshot below, all on latest software. I have 600w of sola, Battery is Fogstar Drift 608ah with internal BMS, heater and temp sensor. Not networked.
I also have a wired temp sensor on the negative battery pole just to keep an eye on rough temps of battery and the general area in electrical cabinet connected to Cerbo GX MK 2, I also have a lynx distributor, and an additional Orion tr isolated to supply some more sensitive devices but not networked.
Question is do I need to utilise the battery temp sensor for STS given the battery can already manage the charging internally from its internal BMS sensor even though it can’t communicate that back to dvcc.
Reading conflicting views on the use of sensor within this type of dvcc setup, and weather I should select it in the sts setting
