Dvcc enabled or not in multi rs 3 fase ess
Should you enable or disable dvcc in a configuration with 3 x multi rs in a 3 fase ess configuration… Where al pv is connected to the multi rs? Batteries are connected to can-bus with a JK BMS.
yes, you do need the DVCC enabled once a BMS is connected into the system.
