DVCC and CONTROL THROUGH BMS
Hello Hello everyone, I need help, I have a completely victron system on my camper except for the batteries and the bms. I chose to try 340ah gotion cells with BMS Daly and so far so good. The problem arises when DVCC and BMS external control is active. or rather if the battery does not complete the charge and the BMS does not pass in an “inactive” state everything works perfectly, even the BMS manages the devices well, but as soon as the charge is complete it passes in an “inactive” state the output voltage of the orion xs, the lynx shunt begins to rise, the charge controller busts all the values, except the BMS that reads the right battery voltage. Better the problem “I’m going to attach some screenshots to make the problem better understood.”
I don’t know if the translation is good
