Dual outlet advice please
hi and thanks for letting me join this community, i get the feeling its goin g to be very helpful and informative . my first question is one about using both ac outlets. my primary for the standard use eg house sockets and lighting to a small casita mainly running fridge and tv permanalty .
my secondary outlet i am hoping to use for an out building for lighting and sockets minimal use plus an electric gate motor Clemsa. my installation is already set up in the out building so the feed will actually be a shorter distance to the fusebox .
sorry to be a bore with the description i was hoping someone may have had a similar set up and could tell me how it shapes up i am running 2 suntaic batteries victron multiplus2thanks in advance
all the best Gareth
Hello, that is pretty much what the second output is for - non and other critical loads.
Just remember it is a switched output so there is a rating for the amps it can run and switch. And that it will need to be programmed unless you definitely want it off during a power outage (default behaviour is this)
Hi ..and thanks for the quick reply …silly question time now can I use them both at the same time .. apologies for my ignorance!!!
All the best Gareth
Yes, that’s what it’s intended for. One is the UPS, and the other is for less important loads that don’t need to be powered during a power cut.
