Does the VM-3P75CT & VM-3P5A log VA and PF in VRM
Does the VM-3P75CT & VM-3P5A log VA and PF in VRM as time-series data? I’m working with a customer that runs a summer camp off-grid on three phase diesel generators. They have no energy meters with logging and they can’t tell me what their peak and average loads and daily energy needs are since they don’t log the data. The camp uses three phase commercial equipment in the kitchen (i.e. mixers, refrigeration) and three phase septic lift pumps and well water pumps so I want to log VA and PF along with real power. I could buy a 3rd party energy meter with logging to place there, but since I want to eventually install a Victron system with solar and generator backup I thought I could deploy a Cerbo GX + VM-3P5A (when it eventually ships) with 200A CTs to log the data and then re-use the VM-3P5A to meter the generator in an eventual system.
I can’t find confirmation whether or not the meter logs this data historically through VRM.
Thanks!
I have 2x VM-3P75CT meters, one configured as an EV charger and the other as PV inverter. All I can find in the VRM advanced tab are voltage, wattage, and amperage.
I think you can pull the values you want via Modbus and/or Node-Red, but would need to log them somehow. 9. Appendix
Thank you so much. Can you please tell me which version of firmware you running on your VM-3P75CT’s? There was a FW update in 2025 to display PF, but it doesn’t say whether or not it logs to VRM or is only visible in VictronConnect. Thanks :slight_smile: I see that I can use NodeRed and an external database to do it, but I’m hoping I can just leverage the GX + VRM to do it for me. I wonder if that makes me lazy? haha
Ha - not lazy! The meters on the latest FW v1.11. I can certainly see the PF/VA data in VictronConnect, just not the historical VRM data. I haven’t 100% confirmed those endpoints are exposed via NodeRed (though I figured worst case you can use Modbus directly). I can check if you need.
One idea, for the lazy :slight_smile: You could set up a virtual meter in Node Red and pipe the VA / PF from the physical meter to the wattage or voltage in the virtual meter. That should be pretty painless, a bit of a hack, but if it’s just for you…
I really appreciate you answering my questions for me. I hope you have a great weekend!
Hi @OGPS, VRM does log PF for both the VM-3P75CT and VM-3P5A. You can add the info to a custom widget.
Apparent power isn’t stored but is available in the “Grid meter combined” widget (which is simply the stored voltage multiplied by current).
Awesome. Thank you! I’m eager to try this out when the VM-3P5A becomes available where I am.
Interesting! Does this work under all role types? I’m having trouble finding them for my two meters, but as mentioned they’re configured as an EV charger and PV inverter.
Hi @A-P l, no this doesn’t work for all roles.
Power factor is logged for the following roles:
  • Grid meter
  • Ac load
  • Genset
  • Heat pump
Apparent power is only available for the Grid meter role as far as I’m aware.
