I’m trying to disable the automatic Shelly integration –I have no desire to access these devices from the Victron touch screen – frankly speaking it’s a security risk.
I’m using Cerbo GX on firmware 3.81 – and for the life of me there doesn’t seem to be a way to disable the integration? I could firewall this at a network level, but just seeing if there is an easy way from the UI.
If I understand correctly, you can only control the Shellys once you enable the channel for each Shelly via the device settings in the Cerbo. Otherwise, the Shellys should remain “unusable”.
In Cerbo GX menu > Settings > Integrations > Shelly Devices:
All nearby Shelly devices on the same LAN are visible as a list below “Discovered Devices” – and clicking on the device name opens up a page that shows Shelly device’s URL / IP address, and switch (“Channels”) names.
What I’m trying to stop: Cerbo GX identifies ‘non solar’ devices on my LAN, makes that information available to VRM / remote management / the touchscreen.
I can move Cerbo GX to a different subnet, make new firewall rules, and reconfigure my Home Assistant … a bit of a hassle to undo a new feature.
That is just a list of the MDNS-discovery messages each shelly is shouting into your network.
Having everyone seeing this is the purpose of mdns-discovery, not a security risk.
The gx won’t connect to any device or create a acload on the gx unless you enable one of the shellies to be used in your system.
If you don’t like the gx to catching up mdns broadcasts, you may eventually block mdns forwarding for the gx in your router / switch, then it won’t pick up anything?
If that’s not possible and you still want it to stop, the only way would be to disable the shelly service after system start, but this requires ssh-access to your gx.
SSH-Way
Create a file to handle auto-start commands:
nano /data/rc.local
add the content
#!/bin/bash
svc -d /service/dbus-shelly
hit Ctrl+X, confirm save question with Y.
Make the file executable with chmod a+x /data/rc.local and reboot the gx. It will now deactivate the shelly service after every system reboot.
In one of the next beta versions an option is added to disable the Shelly integration completely. It will be in the Settings->integrations->Shelly devices menu.
Note: The current beta already has the switch in the GUI but the backend doesn’t respond to it so it doesn’t work yet. The backend part is added soon.
