Dess green mode broken or bug with balancing?
Since today my system (always green mode) is, for some reason, loading from the net at the cheapest moment (which is currently still very expensive!) and dumping it for a few cents profit at night. As far as I know the system has balanced on the 5th and 10tg of this month, set each 2 weeks.
But; there is no message that this behavior comes from balancing. So.. What is happening??
Is frustrating the system asks monitoring throughout the day!
And the chart right at the bottom of that page?
This one?
YES, it doesn’t really look like a balancing thing, but rather a deliberate choice by DESS, because it actually charges the battery right up to full so it can sell some of that power back overnight. I assume you’ve checked that green mode is actually switched on. It could also be a balancing cycle, which would fit with your 5th and 10th, since yesterday was the 15th. That’s every 5 days. But that doesn’t fit with your “every 2 weeks” either. I’d check that setting again.
The settings are as I said: every two weeks, Green Mode.
On the 5th and 10th, it was manually triggered, so to speak, to balance the batteries, because I let them charge to 100% myself at the time. Then suddenly it also says “balancing today”.
If this is balancing, why doesn’t it say so there?
You coud disable the balancing and see if the schedule for tomorrow changes?
Then we would know, if that is caused by the balancing function or not.
And have you set any scheduled charging times on the device itself? I’m guessing not, but just checking.
So.. Suddenly the balancing message appeared this afternoon. About today.
But since I had Dess off, it didn’t. Tomorrow though, it won’t try again, see Screenshots.
I think I saw, after 3 failed attempts it will skip balancing?
Maybe a glitch of the system, so it indeed tried to perform balancing but the message wasn’t displayed for some reason?
Is there an option (yes, I know, 2nd question in one topic..) to have the ability to say, always perform balancing on Saturday. Or, only perform balancing if it’s also financially good?
