DESS Does not reset Battery Balancing issue, after more than 3 days of balancing
Since friday 21st august there was plannend execute a battery balancing.
This was visible in the VRM Portal by the “Battery balancing is scheduled for this day.”-message.
That was reached, my BMS reported a balanced state after a few hours. However DESS did not accept it. Setpoint stayed at 100%.
Although report of Voltage max came from my BMS after that.
In the evening the energy prices rose so DESS deciced to keep trying to charge anyway, prosponing the battery balancing to the next day. As expected, the same behaviour happened today: DESS keeps trying to balance the battery although adsortion and floating has been achieved for several hours.
I then tried again to switch off the balancing, that also didn’t reset the frame.
Further info:
VRM Portal ID : 514082
Venus OS v3.75
DESS in trade mode
Two questions:
  • Are other users experiencing this as well?
  • Can someone at Victron reset the bit “Battery Balancing is due”?
Thanks in advance.
Sensitive info removed and moved to the dedicated DESS category.
As per request. Altered
