I’ve got a Winston Lifeypo4 battery in my camper, and two MPPT 100/50 chargers.
I noticed, that now in winter, the battery doesn’t get fully charged during a day, because the MPPTs switch to Float although there would be enough sun.
Right now I’ve got the standard settings for Lifepo (although this might not be ideal for Winston/Lifeypo4).
Is this caused by the default maximum absorption time of 2 hours?
Or is there any kind of reset if the battery is not fully charged, and it starts a new cycle?
In this scenario, winter and low sun, should I switch to the adaptive mode?
@Ludo at the moment it’s only a 60AH 12V Winston Lifeypo4 battery.
I’m building a 300Ah one currently.
I’ve got dual 450W Panels, with a 100/50 smart solar each.
I also have a smart shunt. All of them are in a network.
The use is a camper, so I’m wondering, if in winter there is not too much solar energy, and it
charges only slow - if the absorption time is limited to 2 hours, it will never get full?
So the actual problem seems to be that it’s leaving bulk too soon.
Unfortunately, I have no readout for the charging status, so I have to watch closely on my phone.
I also read that a smart battery sense might help as the MPPT could read the voltage wrong - although it’s only around 1m cable.
If your battery voltage is 14.2v for 2 hours , it is at 100% Soc.
Your shunt has not reset to 100% as the settings are not quite correct. Esp the tail current of .6amp to reset Soc.
Lithium batteries will happily convert overcharge into heat, and still absorb 1% charge rate.
