Debian repo 404
Hey folks, I’m trying to set up a debian machine following the wiki instructions but I got a 404 trying to apt update with the victron debian repo. Is this a temporary blip or a bigger issue?
The full log
root@oaxaca-negrita:~# echo "deb [trusted=yes] https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie main" > /etc/apt/sources.list.d/victronenergy.list
root@oaxaca-negrita:~# apt update
Hit:1 http://ports.ubuntu.com/ubuntu-ports noble InRelease
Get:2 http://ports.ubuntu.com/ubuntu-ports noble-updates InRelease [126 kB]
Ign:3 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie InRelease
Ign:4 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie Release
Get:5 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease [126 kB]
Ign:6 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main arm64 Packages
Get:7 http://ports.ubuntu.com/ubuntu-ports noble-backports InRelease [126 kB]
Ign:8 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main all Packages
Get:9 http://ports.ubuntu.com/ubuntu-ports noble-updates/main arm64 Packages [749 kB]
Ign:10 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main Translation-en
Ign:11 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main arm64 Components
Ign:12 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main all Components
Ign:13 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main Icons (48x48)
Get:14 http://ports.ubuntu.com/ubuntu-ports noble-updates/main Translation-en [172 kB]
Get:15 http://ports.ubuntu.com/ubuntu-ports noble-updates/main arm64 Components [149 kB]
Get:16 http://ports.ubuntu.com/ubuntu-ports noble-updates/restricted arm64 Components [212 B]
Get:17 http://ports.ubuntu.com/ubuntu-ports noble-updates/universe arm64 Packages [941 kB]
Ign:18 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main Icons (64x64)
Ign:19 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main Icons (64x64@2)
Ign:20 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main all c-n-f Metadata
Get:21 http://ports.ubuntu.com/ubuntu-ports noble-updates/universe Translation-en [238 kB]
Get:22 http://ports.ubuntu.com/ubuntu-ports noble-updates/universe arm64 Components [308 kB]
Ign:23 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main arm64 c-n-f Metadata
Get:24 http://ports.ubuntu.com/ubuntu-ports noble-updates/multiverse arm64 Components [212 B]
Get:25 http://ports.ubuntu.com/ubuntu-ports noble-security/main arm64 Components [5700 B]
Get:26 http://ports.ubuntu.com/ubuntu-ports noble-security/restricted arm64 Components [212 B]
Get:27 http://ports.ubuntu.com/ubuntu-ports noble-security/universe arm64 Components [52.0 kB]
Get:28 http://ports.ubuntu.com/ubuntu-ports noble-security/multiverse arm64 Components [212 B]
Get:29 http://ports.ubuntu.com/ubuntu-ports noble-backports/main arm64 Components [208 B]
Get:30 http://ports.ubuntu.com/ubuntu-ports noble-backports/restricted arm64 Components [216 B]
Get:31 http://ports.ubuntu.com/ubuntu-ports noble-backports/universe arm64 Components [11.7 kB]
Get:32 http://ports.ubuntu.com/ubuntu-ports noble-backports/multiverse arm64 Components [212 B]
Err:6 https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie jessie/main arm64 Packages
  404  Not Found [IP: 157.185.178.148 443]
Fetched 3006 kB in 16s (187 kB/s)
Reading package lists... Done
E: Failed to fetch https://updates.victronenergy.com/feeds/venus/release/packages/debian-jessie/dists/jessie/main/binary-arm64/Packages  404  Not Found [IP: 157.185.178.148 443]
E: Some index files failed to download. They have been ignored, or old ones used instead.
There is no debian-jessie repo on Victron server.
Take a look at Index of /feeds/venus/release/packages
Got it, looks like I missed an important detail in the wiki:
In case the debian and raspbian folders are missing, then thats usually because there was some issue with building the packages. And, since its least important, we then sometimes disable building them. Rather than delaying a Venus OS release to first fix these packages.
Bummer!
