I have a question about integrating Shellys. I have one connected to my domestic hot water heat pump, and it works great. The VRM display also shows it as “Heating”, since I selected the “Heat pump” option in the setup.
Now I want to monitor the main heat pump with the 3EM. So far, so good; I’ve also assigned it the “Heat pump” role. The result is that when it’s running, only this consumer is shown in the VRM.
I’ll attach two pictures to illustrate.
In picture 1, it should look like this, with Heating also displayed. In picture 2, the main heat pump was running, and only the consumer is shown.
Both Shellys are defined as “Heat pump”.
