Hello everyone ![]()
As I can see in my “Preview”, these power curves are obviously available “for one day”. Both for the loads and for the solar yield. I would basically just need to “combine” them in a chart to create a daily curve, or be able to show them individually with the option to toggle them off.
You can combine hundreds of parameters in a chart in the VRM Portal. But where does Victron get the data shown here? Output Power, on the other hand, shows me the Victron-specific energy flow (when the battery is charging..)
I’d like to combine these in one chart and show the power (consumption or generation curves) together as a single overall curve, but also be able to access the values from the charge controllers/PV circuits if needed.
In the customisable widgets, Power1 in watts only relates to one phase, so would I first have to add the three phases together?
