A bad connection appeared after 18 months of use and 1 of the MC4 connectors of the MPPT is damaged after the connection started to melt. Probably a bad crimp? Although it was found working in order and within normal temperature under load after initial installation. Staubli connectors where used. I also wonder is the melting was quite high up if it was not on the MPPT side where the issue is.
Can I order this part somewhere and fix it myself? Or only via a certified retailer or via Victron? I’ll get the non MC4 next time. Or would this be a warranty case, I doubt it after more than a year of use. The MPPT still works fine on the other male connector after crimping a new MC4 plug.
The first photo shows a “minor melting” just at the “mating” area between the male and female.
Now look the second photo, at that little bubble on the cable, the heat inside the crimped area spread out to 2 sides and created that bubble, so, it was a bad crimp in the cable connector.
Ok, now the repair, open the inverter and remove that board part, solder the old one off (suction pump), then go to your local electronics parts supplier, show it, and buy a new one, or get one by any internet shop.
If you cannot do that yourself, then your local electrician can repair that for you, as it is not a mayor repair.
Be aware, electric soldering has a risk, specially these cheap ones, some can create voltages and destroy the board, we use a grounding wire to eliminate that, or in more delicate repairs we use gas operated tools and/or even grounding wires on our wrist and a grounding mat for the board against static electricity.
Thanks for the replies. I’ll investigate the fix with a local electrician.
Max current over the 6mm wire was ~25A. Well within limits of the wire and connector. I’ve crimped another MC4 connector on the same wire and have been using it on the other male of the MPPT without issues so far. Have checked with an IR camera a few times, max temp I’ve seen is 34 degrees C in a 25 degree environment.
Perhaps you can tell where the problem occurred once you open the connector.
I wouldn’t make a blanket statement that it was poorly crimped.
As a rule, I always use a plug-and-socket pair from the same manufacturer. The first and last module get new connectors at the cable connection. That’s what I was taught: MC4 isn’t always MC4. And wherever you order combiner boxes or PV switches from, you almost always get the corresponding mating connector included. Victron seems to be the exception, which made me wonder. IMO, Victron should include the matching connectors.
I’m familiar with the problem with connectors too. On the one hand, there are many connectors on the market that are sold as “MC4-compatible” and then mixed indiscriminately on construction sites. For this reason, I tell our installers (and teach them the same thing during training): always use matching connector pairs, and replace the connector on the first and last modules. I usually use ones from Weidmüller, often the Snap In version. The site managers are trained to check this, no ifs or buts.
Having the matching counterpart connector included is often just wishful thinking…
Whether I have a 7 or 30 MWp system, there’s always a chance of a wrong connector being used (even the modules are sometimes from different manufacturers).
As for what caused the melting in this particular case, we can only speculate in the end, or remove the KPT and send it to a testing laboratory. Udo
