I’m currently running a Cerbo GX with a customized GUI v2. I’ve made some UI changes and use it both via HDMI display and through WASM-based Remote Console over SSH—everything works perfectly in those environments.
However, when I access the same Cerbo GX system via the Remote Console on the VRM Portal (through the VRM logger), I notice that the GUI there does not reflect my custom GUI v2 changes. Instead, it shows the default standard GUI-v2.
I’m wondering:
Why doesn’t the VRM Remote Console reflect my customized GUI v2?
Is there any caching or version mismatch happening on the VRM logger side?
How can I ensure that my custom GUI is visible when accessing via VRM?
VRM uses a cached version of the gui, when available, in order to speed up the startup of the remote console. The way VRM currently determines which gui to show is determined by the sha256 sum of the .wasm file, which is stored on the local GX in the venus-gui-v2.wasm.sha256 file.
So if you have custom gui build, you will also need to update the sum in that file and restart vrmlogger or reboot the GX. After that VRM will no longer be able to find the .wasm file in its cache and download the gui-v2.wasm file from your system instead.
Note that VRM only caches the official releases and won’t magically start caching your own .wasm file, meaning that it will always take longer to start up the remote console via VRM if you have a custom one.
Only the files in /var/www/venus/gui-v2 are used for the gui. Just make sure the venus-gui-v2.wasm.sha256 matches the sum of zcat venus-gui-v2.wasm.gz | sha256sum. As vrmlogger only reads the contents of the file on startup, you then either need to restart vrmlogger or the GX to make sure the new checksum gets transferred to VRM.
Then should have updated Gui-2 WASM over VRM, right? but it does not update it. i removed my installation device from VRM portal and again added it. to recheck it is updates or not. but it does not. I think I might be missing something very important.
The venus-gui-v2.wasm.sha256 file must contain only the checksum and not include any file paths or extra information.
Sorry to disagree, but you are making the wrong statement here. The checksum is taken from the first part of the line (see here). The code doesn’t look at anything after the first part.
Simply doing (on a root filesystem that is rw):
zcat /var/www/venus/gui-v2/venus-gui-v2.wasm.gz | sha256sum | tee /var/www/venus/gui-v2/venus-gui-v2.wasm.sha256
Overwrites the file to contain the correct checksum (and a dash as second part).
After running that, svc -t /service/vrmlogger is sufficient to update vrmlogger.
Thanks to community input, I discovered that the VRM UI retrieves the SHA256 hash from the following location:
/var/www/venus/gui-beta/venus-gui-v2.wasm.sha256
This behavior is defined in:
/opt/victronenergy/vrmlogger/filemonitor.py
Specifically, in the start() function:
def start(send_data):
# Check every 10 seconds
GLib.timeout_add(10000, partial(on_timer, send_data, FileMonitor.monitors, {}))
# Instantiating the class persists it in FileMonitor.monitors. Add all monitors below.
SwUpdateMonitor("/var/run/swupdate-status", "us")
NodeRedCapabilities("/data/home/nodered/.node-red/node_modules", "nrCaps")
Sha256SumGuiV2Wasm("/var/www/venus/gui-beta/venus-gui-v2.wasm.sha256", "guiHash")
Hi @James_Potter , did you perhaps by accident delete and recreate the original directory or the symlink at some point?
The two mentioned directories are the same, gui-v2 is a symlink to gui-beta, so as far as the rest of the system is concerned it is the same directory. Could you perhaps check your system to make sure it still looks like this?
root@ccgx:~# ls -ld /var/www/venus/gui-{v2,beta}
drwxr-xr-x 2 root root 1496 Mar 9 2018 /var/www/venus/gui-beta
lrwxrwxrwx 1 root root 23 Mar 9 2018 /var/www/venus/gui-v2 -> /var/www/venus/gui-beta
and it shows both gui-v2 and gui-beta as actual directories:
drwxr-xr-x 3 root root 4096 Jun 10 03:35 /var/www/venus/gui-beta
drwxr-xr-x 3 root root 4096 Jun 10 03:34 /var/www/venus/gui-v2
Looks like I must have accidentally deleted and recreated gui-v2 as a physical directory during development, which broke the intended symlink behavior.
I’ve now fixed it by removing the directory and restoring the symlink:
