cmorewood:
I would like to see the same in the SOC chart in VRM this would enable, should everything stay pretty much the same, the user to adjust discharge to arrive at a specified SOC at a specific time. The units should be perhaps 1, 2, 3, and 4 hours or perhaps ther could be a dropdown menu for up to say 6 hours?
This can easily be done via Node Red. I use a Node Red flow to set the “grid setpoint” according to current SOC, minSOC and solar yield forecast. The solar forecast can be easily queried via the VRM-API node.
I have 5.4 kWp installed solar power, and have just a MP2-3000 which can deliver not more than 2.4 kW. To be able to feed in all excess solar power to the grid I use my 15 kWh battery as a buffer and feed in from battery over night.
Edit: The flow uses a global variable “global.vrmSiteId” to hold your individual VRM Site Id. This Id should not be published. Use an extra flow to set this global variable according to your individual valie.
"id": "cecfa760836ea314",
"type": "inject",
"z": "1459d4d7551ca112",
"name": "execute_every_1h",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "3600",
"crontab": "",
"once": true,
"onceDelay": "0.5",
"topic": "",
"payload": "",
"payloadType": "date",
"x": 170,
"y": 140,
"wires": [
"83e1731df2cb4a4f",
"4509958d36211e97",
"58bf60b68439ec53"
"id": "83e1731df2cb4a4f",
"type": "vrm-api",
"vrm": "cca5d0a225796a2b",
"name": "forecast_today",
"api_type": "installations",
"idUser": "",
"users": "",
"idSite": "{{global.vrmSiteId}}",
"installations": "stats",
"attribute": "solar_yield_forecast",
"stats_interval": "15mins",
"show_instance": false,
"stats_start": "bod",
"stats_end": "eod",
"use_utc": false,
"gps_start": "",
"gps_end": "",
"widgets": "",
"instance": "",
"vrm_id": "",
"country": "",
"b_max": "",
"tb_max": "",
"fb_max": "",
"tg_max": "",
"fg_max": "",
"b_cycle_cost": "",
"buy_price_formula": "",
"sell_price_formula": "",
"green_mode_on": "",
"feed_in_possible": "",
"feed_in_control_on": "",
"b_goal_hour": "",
"b_goal_SOC": "",
"store_in_global_context": false,
"verbose": false,
"x": 380,
"y": 80,
"wires": [
"b6d55740f5a71d7d"
"id": "9a0e3d6e3a04fda2",
"type": "change",
"name": "Korrekturfaktor",
"rules": [
"t": "set",
"p": "forecast_tomorrow",
"pt": "flow",
"to": "0.9*payload.totals.solar_yield_forecast",
"tot": "jsonata"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "forecast_tomorrow",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 200,
"wires": [
"bc15c2dd4db42c81"
"id": "b6d55740f5a71d7d",
"type": "change",
"rules": [
"t": "set",
"p": "forecast_today",
"pt": "flow",
"tot": "jsonata"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "forecast_today",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 80,
"wires": [
"ce10e89d55ef11a6"
"id": "53ec77049a4d0973",
"type": "victron-input-battery",
"service": "com.victronenergy.battery/512",
"path": "/Soc",
"serviceObj": {
"name": "Batterie"
"pathObj": {
"path": "/Soc",
"type": "float",
"name": "State of charge (%)"
"name": "currentSOC",
"onlyChanges": true,
"roundValues": "0",
"x": 190,
"y": 300,
"wires": [
"e2356f404424d7e5"
"id": "f2a2c02c8c22031a",
"type": "inject",
"name": "execute-oncedaily",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "11 00 * * *",
"once": true,
"onceDelay": "0.6",
"topic": "",
"payload": "",
"x": 170,
"y": 400,
"wires": [
"07f9999728e60555"
"id": "4509958d36211e97",
"type": "vrm-api",
"name": "forecast_tomorrow",
"idUser": "",
"users": "",
"stats_start": "bot",
"stats_end": "86400",
"use_utc": false,
"gps_start": "",
"gps_end": "",
"widgets": "",
"instance": "",
"vrm_id": "",
"country": "",
"b_max": "",
"tb_max": "",
"fb_max": "",
"tg_max": "",
"fg_max": "",
"b_cycle_cost": "",
"b_goal_hour": "",
"b_goal_SOC": "",
"verbose": false,
"x": 390,
"y": 200,
"wires": [
"9a0e3d6e3a04fda2"
"id": "07f9999728e60555",
"type": "function",
"name": "minSOC_saison",
"func": "// Aktuelles Datum abrufen\n// const d = new Date();\n// let cmonth = d.getMonth(); // 0-11\n// Monat um 1 erhöhen, um 1 bis 12 zu erhalten:\n// cmonth++;\n// let currentdate = flow.get('cdatearray');\n// let cmonth = currentdate[0];\n// let cmonth = flow.get('cmonth');\n\nlet d = new Date();\nlet cmonth = 1 + d.getMonth();\nlet cday = d.getDate();\n\n// Berechnung minSOC nach Jahreszeit (Nordhalbkugel)\n// Winter 45%: November (11), Dezember (12), Januar (1), Februar (2)\n// Frühling, Herbst 30%: März (3), April (4), September (9), Oktober (10)\n// Sommer 20%: Mai (5), Juni (6), Juli (6), August (8)\n\nswitch (cmonth) {\n case 1:\n minSOC = 40;\n break;\n case 2:\n minSOC = 40;\n break;\n case 3:\n if (cday < 15) {\n minSOC = 35;\n } else if (true) {\n minSOC = 30;\n }\n break;\n case 4:\n minSOC = 25;\n break;\n case 5:\n minSOC = 20;\n break;\n case 6:\n minSOC = 20;\n break;\n case 7:\n minSOC = 20;\n break;\n case 8:\n minSOC = 20;\n break;\n case 9:\n minSOC = 25;\n break;\n case 10:\n if (cday < 15) {\n minSOC = 30;\n } else if (true) {\n minSOC = 35;\n }\n break;\n case 11:\n minSOC = 40;\n break;\n case 12:\n minSOC = 40;\n break;\n default:\n minSOC = 40;\n}\n\n// als flow-variablen setzen, um sie weiterhin nutzen zu können\nflow.set ('minSOC' , minSOC);\n\n// Nachricht setzen\nmsg.payload = minSOC;\n// Optional: minSOC auch als Payload für Schalter senden\n// msg.minSOC = minSOC; \n\nreturn msg;\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 380,
"y": 400,
"wires": [
"9b375ebef613ee7c"
"id": "ce10e89d55ef11a6",
"type": "debug",
"active": true,
"tosidebar": false,
"console": false,
"tostatus": true,
"complete": "payload",
"targetType": "msg",
"statusVal": "payload",
"statusType": "auto",
"x": 800,
"y": 80,
"wires": []
"id": "bc15c2dd4db42c81",
"type": "debug",
"active": true,
"tosidebar": false,
"console": false,
"tostatus": true,
"x": 810,
"y": 200,
"wires": []
"id": "9b375ebef613ee7c",
"type": "victron-output-ess",
"service": "com.victronenergy.settings",
"path": "/Settings/CGwacs/BatteryLife/MinimumSocLimit",
"serviceObj": {
"name": "Venus settings"
"pathObj": {
"type": "integer",
"name": "Minimum Discharge SOC (%)",
"mode": "both"
"initial": 20,
"name": "set-MinSOC",
"onlyChanges": false,
"x": 590,
"y": 400,
"wires": []
"id": "58bf60b68439ec53",
"type": "vrm-api",
"name": "forecast_restofday",
"idUser": "",
"users": "",
"stats_start": "0",
"stats_end": "eod",
"use_utc": false,
"gps_start": "",
"gps_end": "",
"widgets": "",
"instance": "",
"vrm_id": "",
"country": "",
"b_max": "",
"tb_max": "",
"fb_max": "",
"tg_max": "",
"fg_max": "",
"b_cycle_cost": "",
"b_goal_hour": "",
"b_goal_SOC": "",
"verbose": false,
"x": 390,
"y": 140,
"wires": [
"4e3e0b44fd6a8109"
"id": "4e3e0b44fd6a8109",
"type": "change",
"rules": [
"t": "set",
"p": "forecast_restofday",
"pt": "flow",
"tot": "jsonata"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "forecast_restofday",
"tot": "flow"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 140,
"wires": [
"4d003d0b786480b7"
"id": "4d003d0b786480b7",
"type": "debug",
"active": true,
"tosidebar": false,
"console": false,
"tostatus": true,
"x": 810,
"y": 140,
"wires": []
"id": "2cc09b109a7328c4",
"type": "inject",
"name": "execute-everyhour",
"props": [
"p": "payload"
"repeat": "3600",
"crontab": "",
"once": true,
"onceDelay": "0.6",
"topic": "",
"payload": "20",
"payloadType": "num",
"x": 180,
"y": 480,
"wires": [
"5096be16a5dae81c"
"id": "5096be16a5dae81c",
"type": "function",
"name": "calc_gridsetpoint",
"func": "let forecast_today = flow.get ('forecast_today');\nlet forecast_tomorrow = flow.get ('forecast_tomorrow');\nlet currentsoc = flow.get ('currentsoc');\nlet minSOC = flow.get ('minSOC') || 20;\nlet missingload = flow.get ('missingload') || 0;\nlet fcrest = flow.get ('flow.forecast_restofday');\n\nlet d = new Date();\nlet cmonth = 1 + d.getMonth();\nlet cday = d.getDate();\nlet chour = d.getHours();\nlet cminute = d.getMinutes();\n\nlet gridsetpoint = 20;\n\nif (cmonth === 5 || cmonth === 6 || cmonth === 7 || cmonth === 8) {\n if ((17 <= chour) && (chour < 20)) { // zwischen 17 und 20 Uhr voll laden\n gridsetpoint = -20;\n } else if ((20 <= chour) && (45 < currentsoc) && (8000 < forecast_tomorrow)) {\n gridsetpoint = -1000;\n } else if ((chour <= 7) && (35 < currentsoc) && (8000 < forecast_today)) {\n gridsetpoint = -1000;\n } else if ((7 < chour) && (chour < 14) && (60 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1400;\n } else if ((14 <= chour) && (chour < 17) && (80 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1800;\n } else {\n gridsetpoint = -20;\n }\n} else if (cmonth === 4 || cmonth === 9) {\n if ((16 <= chour) && (chour < 20)) { // zwischen 16 und 20 Uhr voll laden\n gridsetpoint = -20;\n } else if ((20 <= chour) && (55 < currentsoc) && (8000 < forecast_tomorrow)) {\n gridsetpoint = -600;\n } else if ((chour < 7) && (50 < currentsoc) && (8000 < forecast_today)) {\n gridsetpoint = -600;\n } else if ((7 <= chour) && (chour < 12) && (50 < currentsoc) && (8000 < fcrest)) {\n gridsetpoint = -800;\n } else if ((12 <= chour) && (chour < 16) && (80 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1000;\n } else {\n gridsetpoint = -20;\n }\n} else if (cmonth === 3 || cmonth === 10) {\n if ((16 <= chour) && (chour < 20)) { // zwischen 16 und 20 Uhr voll laden\n gridsetpoint = -20;\n } else if ((20 <= chour) && (60 < currentsoc) && (10000 < forecast_tomorrow)) {\n gridsetpoint = -600;\n } else if ((chour <= 7) && (55 < currentsoc) && (10000 < forecast_today)) {\n gridsetpoint = -600;\n } else if ((7 < chour) && (chour < 12) && (60 < currentsoc) && (10000 < fcrest)) {\n gridsetpoint = -800;\n } else if ((12 <= chour) && (chour < 16) && (80 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1000;\n } else {\n gridsetpoint = -20;\n }\n} else if (true) {\n gridsetpoint = 20;\n }\n\nflow.set ('gridsetpoint' , gridsetpoint);\n\nmsg.payload = gridsetpoint;\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 390,
"y": 480,
"wires": [
"62cff6b823712e53"
"id": "62cff6b823712e53",
"path": "/Settings/CGwacs/AcPowerSetPoint",
"serviceObj": {
"pathObj": {
"type": "integer",
"name": "Grid set-point (W)",
"mode": "both"
"initial": 20,
"name": "set-GridSetpoint",
"x": 600,
"y": 480,
"wires": []
"id": "e2356f404424d7e5",
"type": "function",
"name": "set_flowSOC",
"func": "let currentSOC = msg.payload;\nlet minSOC = flow.get ('minSOC') || 40;\nlet diffSOC = 100 - currentSOC;\nconst fullbattery = 14000;\nlet missingload = diffSOC * fullbattery / 100;\n\nflow.set ('missingload', missingload);\nflow.set ('currentSOC', currentSOC);\n\nmsg.payload = currentSOC;\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 370,
"y": 300,
"wires": [
"id": "7e94cf2671a9b2dd",
"type": "function",
"name": "calc_gridsetpoint_demo",
"func": "let forecast_today = 11000; //= flow.get ('forecast_today');\nlet forecast_tomorrow = 11000; // = flow.get ('forecast_tomorrow');\nlet currentsoc = 65; // = flow.get ('currentsoc');\nlet minSOC = 20; // flow.get ('minSOC') || 20;\nlet missingload = 8000; //flow.get ('missingload') || 0;\nlet fcrest = 11000; // flow.get ('flow.forecast_restofday');\n\n// let d = new Date();\nlet cmonth = 3; // 1 + d.getMonth();\n// let cday = d.getDate();\nlet chour = 6; // = d.getHours();\n// let cminute = d.getMinutes();\n\nlet gridset = 19;\n\nif (cmonth === 5 || cmonth === 6 || cmonth === 7 || cmonth === 8) {\n if ((17 <= chour) && (chour < 20)) { // zwischen 17 und 20 Uhr voll laden\n gridsetpoint = -20;\n } else if ((20 <= chour) && (45 < currentsoc) && (8000 < forecast_tomorrow)) {\n gridsetpoint = -1000;\n } else if ((chour <= 7) && (35 < currentsoc) && (8000 < forecast_today)) {\n gridsetpoint = -1000;\n } else if ((7 < chour) && (chour < 14) && (60 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1400;\n } else if ((14 <= chour) && (chour < 17) && (80 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1800;\n } else {\n gridsetpoint = -20;\n }\n} else if (cmonth === 4 || cmonth === 9) {\n if ((16 <= chour) && (chour < 20)) { // zwischen 16 und 20 Uhr voll laden\n gridsetpoint = -20;\n } else if ((20 <= chour) && (55 < currentsoc) && (8000 < forecast_tomorrow)) {\n gridsetpoint = -600;\n } else if ((chour < 7) && (50 < currentsoc) && (8000 < forecast_today)) {\n gridsetpoint = -600;\n } else if ((7 <= chour) && (chour < 12) && (50 < currentsoc) && (8000 < fcrest)) {\n gridsetpoint = -800;\n } else if ((12 <= chour) && (chour < 16) && (80 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1000;\n } else {\n gridsetpoint = -20;\n }\n} else if (cmonth === 3 || cmonth === 10) {\n if ((16 <= chour) && (chour < 20)) { // zwischen 16 und 20 Uhr voll laden\n gridsetpoint = -20;\n } else if ((20 <= chour) && (60 < currentsoc) && (10000 < forecast_tomorrow)) {\n gridsetpoint = -600;\n } else if ((chour <= 7) && (55 < currentsoc) && (10000 < forecast_today)) {\n gridsetpoint = -600;\n } else if ((7 < chour) && (chour < 12) && (60 < currentsoc) && (10000 < fcrest)) {\n gridsetpoint = -800;\n } else if ((12 <= chour) && (chour < 16) && (80 < currentsoc) && (6000 < fcrest)) {\n gridsetpoint = -1000;\n } else {\n gridsetpoint = -20;\n }\n} else if (true) {\n gridsetpoint = 20;\n }\n\n\nflow.set ('gridsetpoint' , gridsetpoint);\n\nmsg.payload = gridsetpoint;\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 550,
"y": 560,
"wires": [
"315af0a55c88cad9"
"id": "67156c8207c78082",
"type": "inject",
"name": "Demo",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 350,
"y": 560,
"wires": [
"7e94cf2671a9b2dd"
"id": "315af0a55c88cad9",
"type": "debug",
"name": "demo-gridsetpoint",
"active": true,
"tosidebar": false,
"console": false,
"tostatus": true,
"x": 810,
"y": 560,
"wires": []
"id": "2f5522e00a078a17",
"type": "comment",
"name": "Description",
"info": "Global variable:\n\nvrmSiteId = the individual VRM site id\n I set this global variable in an extra flow\n Never publish your VRM site id!\n\nFlow variables:\n\nUpdated every hour:\nforecast_today = VRM forecast for whole today\nforecast_tomorrow = VRM forecast for whole day tomorrow\nforecast_restofday = VRM forecast from now to end of day\n\nPermanently updated:\ncurrentSOC = the current SOC \nmissingload = load (in Wh) necessary for 100% SOC\n\nUpdated once daily:\nminSOC = minimal SOC for ESS, different for each month of the year\n\nUpdated every hour:\ngridsetpoint = Grid Setpoint, to enable grid-feed-in when more solar yield is expected than inverter power\n\nThe gridsetpoint is modified according to month (seasonal difference), hour (discharging full battery over night etc), current SOC and forecast_restofday\n\nThe calc_gridsetpoint_demo can be used to evaluate different settings according to a different system. The variables cmonth, cday, forecast_today, forecast_tomorrow, forecast_restofday, currentSOC, missingload can be set to the values to be tested. Just click on the inject node.",
"x": 140,
"y": 40,
"wires": []
"id": "cca5d0a225796a2b",
"type": "config-vrm-api",
"name": "SolarVorhersage"
