I have Mulitplus 12V/3000/230V (see attached type lD).
I need to check some settings and modify some setting of this Mulitplus.
I use the MK3-USB inverter to connect Mulitplus and PC.
My PC runs Linux Mint and I am using the Linux AppImage of Victron Connect.
I get all devices, which can be connected via Bluetooth, into the Victron Connect at my PC. This works perfectly fine.
However, I cannot connect my Mulitplus with my PC.
When I start VictronConnect (VC), I see under Device list that the VC is trying to retrieve data from a VE.Bus device. However, after 30 sec it stops and displays “Can’t connect, click for details”
Front Rocker Switch
This and the remote control panel switch are on “Charger only”
Communication cables
The cable and the MK3 are brandnew and I checked their connections several times, thus connection should be fine
Old microprocessor unit
How can I identify the firmware number?
I don’t find VEFlash under SW downloads. What kind of SW is this?
Failed firmware update
I clicked several times “Force detection” but nothing the only thing I see is th “Detection in progress” but no results.
As I am connecting the Multiplus via MK3 to my PC, do I need a driver for my Linux PC? Which one?
Windows SW installation within Linux using “Wine”. (Wine is a MS-Windows API implementation)
What kind of experience exists with installation of Victron Windows SW?
(I’m running Linux Mint Cinnamon 21.3)
I am grateful for your helping comments.
