OGPS
(Ed @ Off-Grid Power Systems - offgridps.com)
8
The Lynx Shunt is not accurate and does not properly show consumption. Aside from it connecting seamlessly to the rest of the Lynx products, it has no other value. If it’s for part-time RV use where you can recharge the batteries to 100% often then it’s ok. Otherwise, stick with the SmartShunt or BMV if you want accuracy and proper accounting for energy consumption.
It can be done, but in the Lynx system, the LynX Distributor runs on the Lynx Shunt at 5V via a special cable (RJ10), so you also need a small DC-DC converter from 48V to 5V to power it.
