I’m thinking of buying a TAI ENERGY Lithium Battery Rack, either a 10 kWh or 5 kWh model, to install in a solar system. The system will have a Quattro as a charger/inverter, since it will also have a backup generator, and an MMPPT as a charge controller. My question is about the battery’s connectivity with the Cerbo GX, as I can’t find much information. I don’t know if this battery has already been tested with the system and is fully compatible, or what problems it might cause. (The sales sheet advertises the battery as compatible with Victron.) I would be grateful for any help you can give me on this.
@Levano
The manufacturer is the best one to contact for more information.
It is not on the official list.
Program the system as recommended by TAI.
it is easy to check if they communicate. Make a cable and test it out.
